1 - 14 of 14 Posts
I have been toying with the idea of adding DRL lights. As far as I am aware, there isn't a prebuilt set of headlamps that provide sequential switchbacks and a LED bulbs.
Has anyone taken apart the headlights or know someone who could do the job (just getting into the swing of mods and want to make sure that my car is still MOT passable).
I was thinking that this set of sequential switchbacks would be a good investment and can be put into place with the right tools and what have you.
I am unable to provide the link because I am new but the actual part I was look at is this
Morimoto - STRIPS: PROFILE PIVOT (SEQUENTIAL SWITCHBACK)
http://www.morimotohid.com/white-am...ot-switchback-sequential.html?preselect=53625
If you go on to the site it tells you. The lamp is a straight swap once you set the pins, the indicator plug fits to the kit for the turn signal feed, you then just need an ignition fed +12v and the side light - headlight +12v and your done... :wink3:
1 - 14 of 14 Posts
