Peanut butter and Jelly
I found the most random vibration the other day whilst driving without my stereo on... (hate rattles or squeeks with a passion)
real quiet intermittent vibrating noise like a bee coming from....... the wiper stalk!!!!
rest my finger on it and it shuts up... so random!
The only other one I have is the passenger temp control button vibrates with certain notes coming out of the speaker...
Any advances?
I had a really loud noise coming from what I thought was the round ventilator on the right-hand side of the dash; three or four times I had the panel off - eventually discovered by chance that it was the mph/kph changeover button.
I took the dash off and cut strips from a dishwashing sponge (new one :p)
about 10mm wide 5mm thick and 25mm long which I wrapped around the hollow button and pushed down the tube it runs in, also a strip of black insulation tape about 10mm wide around the button where it passes through the dash.
I also did the same with the panel dimming button which is similar, although it wasn't vibrating.
Changed a couple of bulbs while I was at it.....
Dave
I too have this rattle/buzz from the wiper stalk ... very annoying! It stops if you hold it but rattles again when I let go !! Any ideas/solutions ???
