Hi everyone, just wondering if anyone has tried these before? They are a fantastic price, just wondering if its to good to be true - £150 for a full set.
it's mugged off or MO or you can call me Jerry either or. Mine were drilled, used with EBC Yellow Stuff, my brakes get a good punishing so these discs weren't up to it.Cheers Mugged, were yours drilled or dimpled mate? I hear bad things all the time about drilled.
no problem sausage fingersSorry Mo, I shorted everything. 32 with sausage fingers. Not the best at typing, though I appreciate your advice pal.
Because i took advantage of ABP's offer on stoptech powerslots and pads.Ordered do luck lines and cosworth pads, so its just the discs at £135 I'm thinking of getting. Been doing a bit more searching on other forums and there are a few highly rated comments.
Crowmar, how come you took em off the car if just the pads were rubbish mate?
I hate thorney motorsport, they hashed up a simple job and charged me way over for it. Jokers. they also put a ridiculous map on my car that caused the piston rings to prematurely wear due to bore wash although i cant prove that im pretty damn sure.Yeah Booboo std brakes were fine on the astra. I liked the car and had it superchipped by thorney motorsport. Just wanted to get back in a petrol car. Spent ages going between VXR AND Type R's![]()
Exactly this. +1 buy cheap, buy twice.no problem sausage fingers, if I were you best splash out on some better discs, as a lot of us have gone down the cheaper route and actually ended up spending more in the long run buying better discs to replace the failed cheaper ones.
I think alot of the opinion here is biased towards performance parts. If youre not going to abuse the brakes then I imagine theyre fine as an upgrade based on style only. on my bike i put on the best i can afford without compromise, but i ride my bike alot harder and faster than i drive my car. As with the above maybe avoid the drilled?
