1 - 20 of 49 Posts
So my alarm keeps going off CONSTANTLY. I've seen its a super common fault, but I really don't want to take it to honda as my warranty has run out and they're really into daylight robbery without it (£100 just to drive it into their garage?! No thanks)
Once the car is locked, after about a minute or two the hazards will start flashing- as if it has just locked itself, and then the siren sounds until I unlock it and lock it again. Then it will do the same thing over and over again. Apparently kicking the car doesn't help but I tried!
I had the main battery tested, they said it was fine. Then I gave the car a real good clean and it stopped doing it for a while week- so I cancelled the garage I had booked it into and low and behold, it's started again this morning ?
Any advice?
I love my civic and this is breaking our relationship! ?
Sent from my SM-A310F using Tapatalk
Don't know anything about the alarm you have but I would start with the basics. Does it have a bonnet and boot switch? If so I would check they along with the door switches all function correctly. After that I would start looking at the ultrasonic sensors if yours has them fitted. Check the wiring to the sensor is all ok and also to the alarm for that matter.
:dito:
Odds are that unplugging the bonnet sensor will silence the errant alarm.
Pop off the plastic slam panel and have a root around.
did you check the sensors inside the car? left and right side front of dashboard? i had the same problem with my old car and i changed them and problem solved.
one sensor is transmitter and the other is receiver
Discussion Starter #12
Yep, just disconnect the plug going into the bonnet catch and it will stop going off . Happened to mine
Thanks I'll try that later! Took it to a garage and they can't read the diagnostics which is annoying, so gonna have to try everything to avoid a costly honda bill
No I didn't realise there was sensors inside! What am I looking for?
The actual bonnet latch itself looks OK, but I don't really know what I'm checking for ?
Good, under the bonnet catch is an electrical connector that needs unplugging.
Pop off the plastic slam panel to gain better access.
Discussion Starter #17
Have popped of the slam panel and this is what I see... to the untrained eye looks OK? Have attached pics
3rd pic looks like the bonnet catch showing the alarm cable, un-clip it, close the bonnet (not that it'll make any difference now) and try re-arming.
This, the lower electrical cable at dead centre;
Good pic's btw ;)
Discussion Starter #19
if the problem is not from bonnet position latch sensor as said above,
do you have sensors like the photo's? if yes, take a look them
There's are the only things that look like they could be sensors?
Those are indeed the sensors. Have you tried disconnecting the bonnet alarm cable yet? :wink3:
1 - 20 of 49 Posts
