Good day!
Honda Civic 5D executive 1.8 (2006)
sat nav version glass roof and etc.
i have one problem
NAVI display went dark... (like brightness was set to minimum)
and at the same time
aux in - Dension box installed - no connection
navigation voice - lost
bluetooth - lost
brightness button , day / night, max / min - no effect
lose connector (a took apart everything twice !) - main radio unit, display, navi dvd all tested - non found !
re-soldered main radio unit pins, did not help.
tried to erase everything, put back old original navi DVD. same problem. new org DVD update - same thing
fuses - all ok !
if i unplug battery "+" for a while and then put it back, everything works for 1-3 times and then again problem repeats
Return+Menu+MAP on radio unit will bring system diagnostics check that brings =
navi ECU. - no connection to display and radio unit
where is Navi ECU located ? inside glove box DVD Nav drive or inside radio head unit ?
it's ether something is dying inside navi/radio unit or broken connection wire between units.
to trace wire i need to know where is Navi ECU )))
or any other ideas ?
i have one problem
bluetooth - lost
fuses - all ok !
