Race Taxi Pilot
Hi there,
I'm after the delivered price of a N/S (left) rear Eibach 0.5° (30 minutes) camber shim please.
Need to adjust it to get from it's current -1°28' on the left to match the -50' on the right.
I'm also assuming this will not effect the rear toe, which is currently right where it needs to be?
Ta
Hi there,
Ta
That's no problem. I can supply a camber shim to alter the readings by .3' (half a degree). The shims are £8.50 inc VAT and i can send it Royal Mail for not much.
The only problem would be it effecting the toe. Using our shims, and camber adjustment does alter the toe readings as well. It is difficult to work out by how much, but i'm sure it will effect the toe in some way, meaning you will need a toe shim also.
Rich
