There's a new mod that will sort out the fuel filler cap once and for all. It takes 1 minute to fix:
The device is a small bit of spring steel, a bit like half a bulldog clip:
You simply unscrew the torx screw under the cable release:
And replace the screw with the spring inserted (best to push the whole lot to the rear of the car as you tighten up to make sure the spring is in the correct position):
The cap now pops out with some considerable vigour, you can balance small toys on it and launch them quite a distance:
Give your dealer a call and see if they've got their bag of springs. It's good to be able to pull up at a petrol station, pull the lever and hear a satisfying ber-doing!
