Changed my rear axle over the weekend and figured while I'm doing that I'll get some new bearings too as I'll have everything off anyway.
Checked the part number online and ordered from eBay. When I came to fit they went on perfectly, but I could not get the brake disc back on for love nor money. Thought the stud spacing was off, but if I flipped the disc and tried it the wrong way it went straight on. After a lot of confused comparing of the new bearing to the old ones it turns out the actual round plate with the studs on was a couple of mm larger in diameter on the new ones and wasn't fitting inside the brake disc.
I've checked the part number printed on the new bearings and it looks correct for my 2007 2.2, 42200-SMG-G51. I've messaged the seller to sort a return/replacement but they seem dubious about my claim as the part number matches what should fit.. As I guess I would be to.
I've offered to send photos of both bearings against a ruler or tape to show the difference.
Just wondered if anyone here had replaced their bearings with OEM parts and ran into this issue or knew if the part number changed at some point? At first I thought maybe my discs were the issue, it presumably they wouldn't fit over the factory bearing?
This is a copy and paste of the mini guide I did yesterday in the Meister R coilover section. I've posted it up here too in case any 2.2 owners looking for suspension fixes don't look in the commercial section. It's really easy to do if you have some basic mechanical skills.
A full fitting...
Hi Everyone,
I am sorry if this has been covered, i am a total idiot when it comes to rim sizes/offset etc and just want a straight yes or no answer.
I have a 2010 type r. Standard ride height etc. All standard.
I want these rims Fifteen 52 TurboMac Rims.
Fifteen52 Turbomac Wheel – 18×8.5 /...
I am changing the front shocks and ARB drop links on my 2006 1.8l honda civic. They don't look like they have been touched judging by condition and the bolts/nuts. So I have purchased new ones. The ARB drop links are going to be replaced as I fear there is a high likelihood of damaging the...
Hey guys,does anyone know if the Enkeis RPF1 with specs 18/7.5/ET48 will clear the Spoon calipers on the fn2 without spacers?My setup now is 10mm spacers with the OEM wheels to clear the spoons but I dont want to use spacers anymore.
Hi guys,
Now that winter is coming I'm thinking about switching out my wheels & tyres for a set of winters. I've found a good set with the correct PCD and centre bore, but they're a fair distance away so want to avoid a wasted trip if possible. Has anyone tried this and can confirm that they...
