Hi Guys,
After much troubleshooting and a new AC relay, i've found the following:
AC Clutch doesn't engage and no voltage sent down wire to AC compressor. Condenser fan works when A/C is switched on.
I can put a jumper between the AC relay points and engage the clutch on the compressor. so that makes me think it is either the new relay or the activation of the relay from the ECM? I've tested the relay and it works fine. It doesn't sound like it switches on.
Any help?
Be interested to know the outcome of this. I'm sure mine is working adhoc at the moment - sometimes I've cold other times nothing!!
Workshop manual troubleshooter says to check wire from ECM to relay connection, otherwise it is an ecm problem which needs to be swapped out etc
