1 - 20 of 22 Posts
Hi everyone! First post but been lurking for a while as I've had my 9g since September.
Anyway I have just fitted a Pioneer AVH-X5500BT along with the connects 2 fascia, wiring adapter etc but I am not getting any audio through the car. I have tried a single speaker through the wiring harness and the audio comes out of this so the head unit is fine and also the original head unit works perfectly.
Is there a wire I need to connect the remote wire to for an amp or something? I just have a SE so just the standard speaker system without the additional tweeters etc.
My speakers didn't work too after installing a Pioneer head unit. My audio specialist called an audio supplier and said that my car which is fitted with the Premium Audio System (4 speakers, 2 tweeters, 1 subwoofer) needed to be connected to an amp or something... So just one extra wire needed to be soldered in.
Sorry I'm not exactly sure, but there is another wire you need to ground.
Thanks for the reply but I only have the standard system so no subwoofer or tweeters. There are 2 plugs left over from the original unit which I think may have something to do with it but I don't know.
I helped someone at a speciality shop install an Alpine on a 9G with the same issue.
It actually has an external amp even if it doesn't have the Premium sound system.
(Maybe for noise cancellation - It was on a 1.6 diesel)
There are 2 things to take into consideration:
1. the car amp takes low-level inputs, so you have to bodge some RCA cables
2. there is a remote wire for the amp in the harness. But I completely forgot which one.
Also, after this, the MID didn't turn off properly, but the shop guys fixed this somehow - I'll ask them if I have the chance.
So if you get hold of an electrical diagram, you can easily find which wire the remote was.
Also, the antenna has an external amplifier. More to bodge there.
You sir are a legend - thank you!
If you can find out that would be fantastic.
I also have the 1.6d. Can you elaborate on point 1 what do I do to bodge the RCA's? I have already got the antenna sorted as the harness came with the boosted adapter..
For now you will need 2 pairs of RCA's with about 20cm of wire. This will connect to the inputs of the factory amp in the harness.
I will elaborate soon, with diagrams and stuff. Tomorrow I believe. Just have to find the schematics.
Note: you will have the same sound quality as before, because you will not be using the head units' integrated amplifier.
What was the i-MID issue? I didn't seem to run into any issues, the display works just like from the factory, even the USB to upload wallpapers works just that there is no song information that is being displayed.
@groowe
Have you had any luck with the diagrams yet? Don't mean to push but I really want to get this in as I don't fancy selling up and losing money.
Unfortunately not yet. The good part was that the MID issue was related to a faulty connects2 adapter, so what remains is to connect the RCAs and amplifier external remote.
It's still on my to-do list, just need to find those darned diagrams.
Discussion Starter #12
Right I have got hold of some 9g wiring diagrams for the audio system etc and found the amp remote power (white wire on the main plug with the locking mechanism). I have connected this to the head unit remote wire and the audio is working but is hissing a little and pops a little on startup. Is this because of the low level inputs you said about? Do I need to connect the RCA's to the speaker wires in the loom to cure this?
Mine has the same issue, but you can't hear the hissing when the car is on so I didn't bother.
Does anyone know where the external amp is located in a 9G? Bypassing it would give better sound quality I'd imagine. Was going to get a Pioneer deck and Connects2 fascia kit but now have second thoughts, reading the above comments.
When the time comes, looks like I'll be getting a fascia kit from:
http://www.hondabitz.com/genuine_fascia_kits/civic_2013_full_kit_rhd
There is an OE amplifier interface kit option (available separately). It is possible this interface converts the high level speaker output of the aftermarket deck into a low level input (RCA level signal) suitable for the factory amplifier.
Discussion Starter #16 (Edited)
Yes I would imagine it does. I wish I knew this was available before starting this then I wouldn't have had the hassle of getting wiring diagrams etc
It's not much of a problem if you don't mind the slight hiss when the volume is off. All you have to do is connect the remote wire from the aftermarket loom to the white wire on the main civic radio plug.
I was having similar issues to the poster, got a civic tourer 2014 1.6 diesel and i asked my dealer if i had an amp in the car since i wasen't getting any audio out, it turns out that i do have an amp in the car, so either he was lying to me or should be fired for doing a ****** job ;)
Anyhow, my question is about the last point on the list about the antenna and power to it, if i understand it correctly you only have to use it if you happen to have one of those antennas that are powered by a motor so that when you turn on the car the antenna grows out of the car a bit, yes? I've got a small"shark" fin as an antenna so i won't be needing to use that i think, please correct me if i'm wrong :)
The shark fin is an amplified aerial. It is required to connect the blue wire to a +12V connection.
As to amplifiers, it is on the diesel models (premium sound or not) as it requires extra power to run the noise cancellation system. The microphone is the "speaker" in the headliner. Petrol models the amplifier is on Premium sound head units only.
Weird that they put in an amp on diesel only, with or without premium. Good to know, thanks. I did a quick test a few days ago without connecting +12v to the blue wire and i still got sound on the radio, but i'm guessing that's because it was picking up am/fm radio without the antenna then i guess. I'll make sure the shark fin gets juice when i get my cables from ebay then, thanks again.
does anybody have pictures of them changing the unit and bypassing the amp. I'm still in doubt wheter or not it is worth the trouble. If you have a sd satnav do you still need to replace the fascia or do you only need the cables? (steering controls, pioneer-honda and possibly? the original amp)
I have an 2012 car but I can't fint the amp although its a diesel. how does the amp look? I think its better when you bypass the original weak amp. if it was any good, why would we want to change the headunit right
1 - 20 of 22 Posts
