Hi guys I have plugged an aux input into the cd changer port and now my car will not start.Battery is good and everything else works and still cranks but no green light at all and a scanner can't connect to the ECU .
I am desperate for some help with this if any input would be much appreciated.
Fuses all good, including the big main fuse?
Might you have bashed the dash a bit hard and engaged fuel cut-off, the reset button is located under the dash.
Try starting with the spare key?
Don'thave a spare farqui ,would fuel cut off caus no green light on dash.ps where abouts is fuel cut off Ihave all lower panels and centre cconsole out
It's just behind the steering column, black button pointing upwards from memory.
If it is that, it cranks but doesn't fire.
If it isn't that you've blown a fuse somewhere.
Multimeter in continuity mode. Each fuse has 2 dots where you can test that it hasn't blown, without removing it.
