1 - 17 of 17 Posts
I've just realised that my car does not have the headlight adjuster that some or most cars do on the instrument panel near the engine start button.
I was wondering if there was any particular reason for this ?? As other cars have on this forum I have seen.....
And how would I adjust/level the beam if necessary?
Discussion Starter · #5 ·
Should be standard on an EX, check there's headlight washers in the bumper
Yeah I know there are washers on the bumper, but didn't know they were standard in the EX...
As when I was looking to replace my car, was only looking for the EX models, but they didn't all state that they had HID lights.
The guy I bought mine off, i thought he had put them on...
shameless
if you want to see the system work- gently reverse one rear wheel up a kerb with the lights on and you should see the light beam move
Strong in me The Force is
According to european regulations, cars equipped with HID lights also have to have auto levelling and headlamp washers.
Bringing an old thread back up here but, does the levelling of the HIDs occur upon engine startup? Like can be noticed on some cars with projectors.. Or does it level itself whilst driving?
I've never noticed my 09 CTR level at startup but could of sworn I noticed them adjust whilst going over quite a bumpy road recently..
...............Daedalus
They won't adjust on start-up unless you car has moved since you last started it up.
But yes, they do adjust while you're driving.
If you've got OEM HIDs then you should be able to see the headlight washers on the front bumper.
You'll also not have a manual headlight height adjustment dial on the dash.
Yes, i have washers on my bumper. So to be straight forward it is confirmed if there is OEM HID they must be auto leveling?
I would like to see, them going up and down, maybe i should load my boot, so see changes or smth... Intresting things...
1 - 17 of 17 Posts
