Is there meant to be a lights on warning on the 2009> ES Civic's?
The lights are working fine but I left them on this morning and didn't notice after getting out without an alert/alarm..
Also noticed the interior lights aren't working anymore..
I'LL NEVER WALK ALONE
mine has a lights on warning...
but as i always have them on auto i never see it ;)
Could be linked - if the switch at the front of the door isn't working, then the car doesn't know the door is open to give you the lights on warning? This might also be why the interior lights aren't working.
I'm guessing your car should have a lights on warning - my 07 plate did.
...............Daedalus
+1
Sounds like the door switch is faulty. Do the interior lights come on when you open the passenger door?
Sent from my Sony Xperia S using Tapatalk 2
Passenger door not triggering the interior lights either... guess the drivers door switch could be stuck on/off and is cancelling out the other doors too?
Will get it booked in with Honda as it is still under warranty.
Thanks for the help.
AFAIK the lights should come on no matter which door is opened. Will check later though.
Could be a problem with the MICU, hopefully Honda will sort it :)
