[SOLVED] No warning of lights on
I just recently bought my Honda Civic 2.2 diesel (2005/11) and since then it happened me 2 times that I completely drained the battery with letting the headlights accidentally on. According to the manual there should be a notification of this (sound & display on the dashboard) when I remove the keys but I receive nothing. Is there a way to turn it off/on?
If yes where?
Many thanks
As soon as you open the door the display should show the icon and you should hear beeps. I don't remember anything about turning that feature off being mentioned in the manual. Very similar to what you see/hear if you do not remove the key.
-=SBZ=-
Check see if your door sensors work.
Start the engine and open the drivers door. it should beep and show you a picture of a car on the dash with a door open.
Also should beep if you leave the key in and open the door after turning the engine off.
also in the door shuts you will see or find a rubber bung , if you press this your dome lights should switch off acting as if you have closed your doors
