Hi everyone
Can anyone tell me what it could be?Definitely something wrong.
up to 1:12 there is a strange noise and then back to normal.
i-Vtec
Welcome to civinfo.
Does it do it all the time, at start up or randomly? Have you tried spraying wd40 at the idler pulley?
Welcome to civinfo.
I noticed 3 days ago and it does that when i press acceleration pedal and then its stays for 20 sec and back to normal like on video
With the engine running, get a long screwdriver or rod of some sort & VERY CAREFULLY place the tip on the alternator casing, idler and other items driven by the belt - put the other end to your ear - you will hear a much better indication of what is causing the noise. Better still get a mechanics stethoscope but a long screwdriver works fine & is what I use.
I stress - do this VERY CAREFULLY - do not let whatever you are using slip onto the belt or get entangled for obvious reasons - you will get a good read on the noise from touching and listening - you do NOT need to place the end right near the belt - simply on the suspect component will work just fine.
This is a time tested & accurate way to identify the source of noises in a belt train like this appears to be.
PS - I accept no liability for anyone who does not take sufficient care carrying out this procedure & if you are uncomfortable with this basic diagnostic I'd suggest you take it to a professional.
