1 - 11 of 11 Posts
hi i need advice on my front suspension. i have a 2007 civic ex which i purchased in december 2010 with 20000 miles on the clock. since i got the car i have complained to the dealer of the noisy suspension when going over bumps but they say there is nothing wrong its just normal as this model has very stiff suspension. i dont agree and its got to the point that i just want to trade the car in. i have spoken to trading standards and they say if there is a fault it should be fixed. surely they are telling me pork pies and this isnt normal. i did get the drop links done but this didnt help. any ideas?
Cockup Specialist
You need to be very specific on the exact noise that you hear and when
Then we might be able to help ;)
Cockup Specialist
Theres several faults recorded.
1. worn top mounts (even just loose bolts on occasion)... replace
2. dried shock.... they have a greasing procedure.
3. drop links... just done.
4. subframe stick/slip...unbolt, drop, clean and grease surface (metallic clang when braking or accellerating hard)
5. Bushes is very very rare.
6. dropped bumpstops.
Do a search on here for those problems and see if you recognise any of them along with the symptoms
:thumbsup:
use the search between stickrs and rules....up there on the right :D
Thats great i will look into these problems. the biggest problem is getting the dealer to admit there is a fault
Its not under warrenty but trading standards said any problems within 6 months of purchase should be fixed by the dealer
i've had the same problem with my car and no matter what thay change the only thing that stops it for a while is the "sub frame modification" thay they do where they drop the sub frame and clean and re grase it
i spoke to the dealer today and they are adamamt that this is just the characteristics of the car and have asked me to go out a drive with the foreman in a company demo car so they can prove its the same with all the civics. i only bought the civic as we had a baby and needed a 5 door. i traded in my bmw 3 series coupe god i wish i still had it.
I had the same when I bought my 1.4 Civic new, be careful in my experience they will just to make out it is a characteristic. If you dont get any joy write to the Chief Executive of Honda UK and complain bitterly.
I felt the same way as you got rid of a perfectly good car 7th Gen car for a new car with unacceptable characteristics.
1 - 11 of 11 Posts
