1 - 12 of 12 Posts
fusion1296 - if you search for TomTom I think you'll find that its a big thumbs up on this forum. I currently run TomTom 5 on my HP iPAQ and it is brilliant. Is the link for a new Palm plus the software and a GPS receiver ? If you already have a Palm you only need to buy the software and a GPS receiver.
This site has a lot of information --> http://www.pocketgpsworld.com/
Discussion Starter · #3 ·
HI Newboy,
thanks for you very quick reply , the link is £300 for the lots , softward PDA and receiver , i only have a Palm Zire so wont be able to use that so a good excuse to get a new PDA at the same time .
the link is for a Palm TX and TomTOM 5 but i beleive the reciever is a palm one, (hard wiired) not the TomTom BT one ?? not 2 sure really
No probs. Just had a look and it seems to be a bluetooth GPS unit !!
Box Contents
Bluetooth GPS Receiver
Recharging cable for smartphone & GPS Receiver
Cigarette lighter adapter
Vehicle device cradle with windshield mounting bracket & suction cup pad
TomTom Navigation Software 5 and the maps of the UK preinstalled on a memory card
Had a quick look around and not many places seem to do that model so don't know if you can get it any cheaper.
Discussion Starter · #5 ·
hi Newboy,
thanks for your help, with me being new to sat nav , is it ok that the software is preinstalled on the card ? what happens if the card dies , should it not be on CD or something for backup ? or can i back it up of the card to my PC like i do my other Apps on my Palm ?
the price seems quite good to me , i could get the TX on its own for about £180 so that means i am getting the TomTom 5 for about £120 which seems quite good?
thanks again for your help :)
If you need Satnav all of the time, ie. it needs to be usable and reliable alot; then get a satnav unit (like the tomtom one)
Both me and my father have PDA's with Satnav and the number of times we've both had to go back to maps (not often admitidally; but sometimes) where my sister has TomTom One and she's never had a problem with the unit!
They're £180 from Currys online at the moment I think; the Garmin is £120
Discussion Starter · #7 ·
HI generationgav,
thanks for the advice , i will be using it probably max 2-3 journeys a week and also in both the car and a van so it needs to be portable i also need a new PDA so thought the above would be best ?? its very diffucult to decide i belive the option you are saying would be best but not as flexable ?
fusion1296 said:
HI generationgav,
As it said; it just depends on your requirements. My PDA/TomTom option works pretty well for me to be honest; it works 99% of the time, I can use it as a PDA but also as a satnav when needed; it's also for me quite a neat solution as I have the bluetooth reciever in the boot so I just stick the PDA in.
The thing is; when it goes wrong which it sometimes does (and did this morning ironically) it can take a while to fix; this morning I went on a whim and left without it (the PDA and Bluetooth reciever decided to unpair themselves!) but if it was importantly needed then I couldn't have used it, so it all depends how reliable you NEED it to be. If it's important it works 100% of the time immediatly then the PDA route isn't the best way, however the PDA route is more convinient as you have a pda too!
Sorry, I rambled a bit there; but hope I explained myself somehow!
fusion1296 - I think its only the maps that are preinstalled on the SD card. As you say the software will most likely come on a CD which you'll need to load onto the Palm via a PC. I'd also guess there is a backup of the maps on a CD in case the card goes faulty.
I don't use my PDA for sat-nav that often and I have a GPS compact flash receiver so it plugs into my iPAQ and I don't have any of the Bluetooth pairing issues generationgav mentions but I have had no problems whatsoever when I have used it.
Discussion Starter · #10 ·
HI , yes i agree , a decision between realiability and having a pda / sat nav .
do you have the tomtom bluetooth receiver Mk 11 ?? i am goign to try to get that one i think the kit from amazon is a palm receiver but not sure that is so good ?
thanks again :)
thanks again :)
I have a third party Bluetooth reciever and purchased the software on it's own as it worked out cheaper as I got a good deal.
It's never TomTom or the reciever I have issues with; it's usually the PDA software or battery! If my batt gets low then it starts to play up as Bluetooth will disable itself.
Also TomTom 6 is going to be out within the next month, so it could be worth waiting for that.
I'd advise you to look at PocketGPS World (TomTom Forum) as there's some clever guys on there who will be able to answer you pretty much anything.[/url]
Discussion Starter · #12 ·
thanks again :)
thanks will have a look there , i am thinking it will be cheaper to get the bits on there own .
1 - 12 of 12 Posts
