KRaZy about it!
I am searching for a solution to a typical problem, but a somewhat atypical case. I am the (proud) owner of an EX GT, which means i have SatNav and HFT. Unlike in my previous car, I therefore don't need to start adding various holders to hold my devices.
I hate the sight of them (why are they all universally so montruously ugly?), and in my previous car, it took less than 24 hours from the time I purchased it until a scumbag broke into it to (unsuccessfully) steal the portable satnav (because i hadn't bothered disconnecting and hiding the window cradle).
However, I still sometimes need to be able to see my phone/PDA, rather than hide it under the armrest or leave it in my pocket. First, because it has a speed camera warning app; secondly, because I like to know who's calling me before picking up with the HFT; thirdly because I sometimes search for things online or IM people.
What I'm after therefore is a solution that will be non-permanent, not attached to the window (I don't want rings), and easily removed and hidden.
I had 2 ideas about that, but haven't yet seen a solution for either:
  • a (discrete) cradle that could be used in the cupholder in the central console, or (even better) attached in or in place of the ashtray. It could then simply be thrown in the glove-cave or armrest when not used. Unfortunately, my phone is too wide to fit in the ashtray, otherwise that would have been my initial attempt (although the screen is then fairly unreadable)
  • a beanbag type of solution, that could sit on the dashboard (by the A-pillar, or between the screens and the speed indicator. It would have to have a anti-slip base (for obvious reasons) and sturdy enough to hold the phone (ideally both in landscape and portrait modes). A flexible enough could even be used in the cupholder as well, hence why it's my preferred solution.
    I found something close to that online, but as it's not meant for the car, I doubt it will be heavy and stable enough: MovieWedge - The Best iPhone, iPod and Portable Media Device Holder/Stand In The World! - Please don't mention the Arkon beanbag/cradle one however, as again, it looks like it was built with someone with no taste, and it's huge!
Any suggestion out there?
Hello again ! ...
The best \ broadest range of in-car solutions are (IMHO) made by "Brodit" ...
You buy a 'clip' to suit your car and where you want to have the device, then a 'cradle' to suit whatever device you have, then screw the two elements together to make the 'mount' that you want ...
In the UK, try here ... Brodit ProClip Mount and Car Cradle Holder Shop ...
However, as the mount needs to be secure, it can't be removed \ refitted once in place - but, they are very unobtrusive when empty ...
p.s. - like in here - http://www.civinfo.com/forum/any-non-civic-chat-here-please/32043-smartphones-clones-5.html#post518877 - especially when you put the power cable in the centre console ....
KRaZy about it!
J., thanks for the info. I should have mentioned that I read most of the threads on related subject on Civinfo and therefore had already come across brodit products. I almost bought one of those for my previous EP model. However, I don't like the permanent or almost-permanent nature of that sort of solution. I'm really after something much less intrusive and much easier to hide / remove / move.
j., thanks for the info. I should have mentioned that i read most of the threads on related subject on civinfo and therefore had already come across brodit products. I almost bought one of those for my previous ep model. However, i don't like the permanent or almost-permanent nature of that sort of solution. I'm really after something much less intrusive and much easier to hide / remove / move.
O.K. - then your best bet is probably what I also considered - i.e. 'cannibalising' the ashtray - (I didn't do this, as I wanted the mount to be forward of the gear lever) ...
1} Buy a 'Brodit' cradle to suit your device (and a charger)
2} Remove the ashtray's metal internals and lid etc.
3} Make a suitable plastic 'slab' and epoxy it in the ashtray
4} Screw the 'Brodit' cradle to the plastic 'slab'
5} Both the mount and the charger can now be removed !
Mine just pulls off as the fixing tape is removed..It really doesnt need it.
It can be removed and put back in seconds.
Its For Sale in the new year
I use the Brodit system with 'mini move' quick release plates. When you leave the car, you hide the device mount so all you can see is just the fairly discreet vehicle ProClip mount. It also allows you change to a different device quick and easily.
More pics here: http://www.civinfo.com/forum/electronics/7144-dashmount-2.html#post340884
