1 - 17 of 17 Posts
i know this is a common problem, im looking at a car on sat which has a slight notch in 3rd but nothing to bad by the sounds of it, but my question is will it get worse, or do they just stay at they are?
It can only get worse
Enjoying life
My gearbox can be a pain in 2nd and 3rd gear when the car is cold. When warmed up it's fine. Have you been told by the seller that 3rd is notchy?
when I first bought 'the pig' It suffered from slightly notchy gear changes at high rpm. Changed the clutch, adjusted the pedal travel, changed gear oil out with MTF3 and put the heavyweight skunk gear knob on.. silky smooth ever since.
yeah well i asked him if it had any problems with 3rd gear, he didnt realise it was a common problem and said it feels different to the other gears but doesnt slip out or anything or crunch, he just has to make sure its in properly which doesnt sound to bad
When i was buing mine i was aware of problem, was looking for it and didn't noticed anything wrong, but... when i was checking the car engine was warm like it has been used earlier. Next day on cold start gearbox was very bitchy - 3rd did "jump out" on couple of ocassions (especially during change in left cornering - strange) so i change oil to Red Line MTL and it did improve situation slightly but on cold start it is still bad. On warm up gearbox it's good.
...if i was you i would search for the car with job done on recall in the past. I know i would have to do it at some point and it's not a nice thing to have on the back of your head.
Get a gearbox oil change straight away I would.
Maybe a silly question but do all gear changes feel differently?
3rd gear is actually my smoothest gear, goes in lovely. 4th, 5th and 6th go in ok but you feel it like catching something if you know what I mean, doesn't make any noise and doesn't pop out, just no where near as smooth.
Discussion Starter #12
yeha all the others feel fine, its jusyt 3rd thats slightly differnt, i had a notchy 3rd in my old fn2 it didnt cause me to much bother really
Mine has this, had the car almost 4 years and learnt to live with it.
IMO my FN2 gearbox is no way near as slick as the box in my old EP3 I had before it.
Not only yours - FN2 gearbox is a disgrace to motorcar industry. This is worst gearbox i ever had on any of my vehicles - bikes and cars through 23 years. :facepalm:
Discussion Starter #16
i bought the car in the end, its not to bad really, just a bit notchy now and then, nothing i cant live with
1 - 17 of 17 Posts
