I need a fuse for my cam that will turn off when the car ignition is turned off.
I tried the cig ones that doesn't work its always on. I can't really test the power either and i don't want to pull the wrong fuse to mess something up.
I have a 1.8 5 door petrol.
I have tried 31,26,27,28 i cant use the ones up near 35 my fuse switch on the cam won't fit. If possible a compatible 20amp(yellow right?) fuse socket as i only have these ones to use (can't use the existing fuses).
Thanks.
i tried 33 and it worked fine. Thanks anyway guys. I think 32 and 33 are fine to use. I also noticed some strange wiring in the port that should be empty. Had like a socket and a lead similar to the camera lead hanging off. Was about to just butcher that wire and test. But didn't need to. Ill show a picture of what was hanging off it. I think a camera was used by the previous owner and they used like a socket and took power off of one of the pins.
