Hi people,
Just bolted on my supercharger kit (ct engineering) and the mapping is being done by Vit.
I'm on stop now as he's saying my O2 sensor is not working correctly. Apparently it wasn't registering the correct readings.
I have now replaced the Denso OEM primary sensor with another Denso sensor which had the exact same wiring colours, 2 black, 1 blue and 1 white
On start up its fine but after a couple of seconds the idle starts to hunt, reving up and down about 400 rpm.. This continues even when warmed up.. No engine codes.
When we pull the sensor cable out it returns to norm (where the ecu is putting a stock figure) and engine code comes up.
Does anyone have an idea what else this could be? Was running fine on the first 2 maps this past week
