1 - 20 of 37 Posts
right after all the issues with the eml, i have now fixed the issue but need to turn off the management light off, have tried discounted the battery for a hour or so and that hasnt worked
i have a ELM327 led but can anyone point me in the right direction for the correct software, i have proscan but this doesnt seem to work
if not ,recormmend a stand alone scan tool off ebay that will work
thanks
Discussion Starter · #3 ·
thanks again... lol
am not looking anything fancy
but there are a few different ones, which software would you say, i only need to turn off the eml light
am i right in when looking at the link you can download a free limited version ???
will the limited version do what i need ??
thanks phil
Not done Civic EML yet (as its not ON in mine) but I did friends Renault Scenic II.
I was using fleabay cheap bluetooth elm327 with android phone and some free aps (type OBD in Market) and it did worked. Showed me error codes and erased EML. It needed few runs of "ERASE" tho.
I also tried same elm327 adapter with bluetooth dongle on EEE PC with some free software of the internet (cant remember the names now - sorry) and it read Civic state and parameters as well.
Thats my experience.
P.S. Save the error codes as you might need it to resolve car fault i.e. what needs to be done.
Good luck
M.
sent from SGS.
Reactions: neil-s
Cockup Specialist
thanks again... lol
thanks phil
You can use it as a free trial download.
I think you may well be able to read and resete the codes with it in trial mode ;)
Phil, sorry mate, just seen your PM about this... TBH I don't know. Relic is your man :)
Before I got my WiFi OBD2 adaptor, I had the bluetooth ELM one thats on ebay http://www.ebay.co.uk/itm/Android-T...iagnostic_Tools_Equipment&hash=item19c9ec554f
It came with a disk of PC software which were supposed to be trials.. but a couple of them when installed on my lappy seemed to be the 'full' version? as everything worked and no sign of limitations Cracked maybe? I don't know if they will clear the codes as I did not play with them too much.
Anyway, before I sold the adaptor, I copied the CD ;) .... I can sent you the files later if you want via email/download when I get home :)
Discussion Starter · #9 ·
going to have a better look at the link relic put up when i get home from work
have to watch internet usage at work
cheers bog, will text you later if i need anything
can you check the cd tho and see if its got scanxl on it
cheers all
Bantersaurus Rex
anyone reccommend a cheap obd2 bluetooth piece if I download Torque for Android?
This one I linked to in this post... £14 :)
Before I got my WiFi OBD2 adaptor, I had the bluetooth ELM one thats on ebay Android Torque Car ELM/327 OBD2 OBDII Bluetooth Diagnostic Interface CAN BUS | eBay
A cheap china "orange/blue" or "big blue" elm327 bluetooth scanner should do the trick (only general PID reading, error reading+erasing no reprogramming)
I've bought a Vgate scanner and waiting delivery.
Realtime data can have a lag (depending on the number of gauges), but only $200 devices seems to handle fast PID reading (loads of reviews on youtube)
i have the elm 327 obdII usb cable and i use proscan5.5 software which works very well on vw, however when i connect it to the civic connects fine and gives no errors, but when you go through the menus on the software like the revs or o2 sensors never shows anything so not to sure when says there's no errors is it telling the truth.
what software are ye using? i have tried scan xl trial
elm327 bluetooth scanner - like already mentioned above - IT WILL WORK !!
2 times in last few months I had Check Engine due high boost pressure and both times with no problems I read fault and with one click on my mobile phone ERASED FAULT. And second time it was on highway at 60MPH - Turbo shut down and engine went in safe mode at max speed, and I turned them ON even without stopping - pulled away again...
And it was free (LITE) version program...and there is same program to buy with more options, but free one was enough to READ/ERASE...
1 - 20 of 37 Posts
