1 - 11 of 11 Posts
do these not struggle in normal day to day running?
OEM battery is 35 AmpHr - much less than that, and there are bound to be issues …
I thought that OEM is 44 or 45 Amph..
The 2.2 has a larger capacity - but, as far as I am aware, all the Petrol versions have a 35 AmpHour unit ...
Whatever the actual capacity is - it's just about as small as Honda could get away with - hence an even smaller capacity unit will have issues ...
In fact, I understand that the unit the 'OP' referred to, only has enough juice to try to start the engine 8 times or so ! ...
I took the decision ... I will try an PC680 ... Hope everything goes fine ...
Buy \ fit 2 units (wired in parallel) ? ...
1 - 11 of 11 Posts
