Evening all,
I've got an 06 1.8ex that is due an oil change. I was going to drop it into the local garage to get this done, but whilst searching through posts on here noticed someone mentioning doing the oil change yourself with a fluid extractor pump? Has anyone done this? Is it an ok method for an oil change, or a stupid option?
Mu understanding is having bought the pump (like this one) you'd insert the pipe down the dipstick pipe as far as it will go, pump the oil out (there should be around 3.6 ltrs come out?) Fill back up with oil 'till the dipstick shows sufficient has gone in?
I don't have the apparatus to safely lift the car up to do a 'proper' oil change, hence this being my only option other then taking it in, as such I can't do an oil filter change as well, is it ok to change the oil without doing the filter as well?
Thanks!
Thanks!
