1 - 9 of 9 Posts
Gadgeteer
Just wanted to check that this is a "design feature" and not a fault. When I use the auto Window full up or full down when the window reaches the top or bottom the door moves.
Is this normal???
Mine does it too.....not sure it's anything to be worried about, not at least until it devolps a squeek or something! :roll: :roll:
This is quite normal on most cars - just a reminder that the whole thing is made of tin foil (but is quite strong when assembled in a certain shape).
12th June 2006 1.8EX
Had this on my last couple of cars as well and agree with Pottsy, it just shows how weak the structure is in certain directions. Still I suppose this 'weakness' is all about crumple zones and safety.
Is it only the plastic which moves though or the outside too?
My last couple of cars did it too, including the past model and the current civic.
I have thought about it and have come up with a theory. I think it is intentional that the glass fits in so tight when closed (tight enough to deform the door slightly) to make the side window stronger, for security. Imagine 2 windows, one loose fitting with some play, and one rock solid, under a bit of tension. Try to break them. Which would be harder to break? The solid one would be.
I may be wrong, but it makes sense to me.
1 - 9 of 9 Posts
