I'm about to order a 2.2ex and was wondering if my phone is compatable with the HFT.
I've looked on www.hondahandsfree.com but its not much help. The phone is actually made my HTC and goes under lots of names buy the HTC name for it is TyTn or HTC Hermes Does anyone out there have the same phone or know if it can be paired and work with the HFT?
ps also known as MDA Vario II
My only other thought was to try at the local dealer...
Chris
I use the XDA mini S which is another HTC PDA phone - I think it is the same as yours without 3G. Works fine on HFT.
should work!
I went to dealer (post ordering) and tried it in an accord with same system (I'm told) and it worked fine so hope it should be the same in the Civ EX!
Chris
Hello
I have an EX and I use an Orange SPV 3100, it works very well. The pairing process was a bit tricky but once the connected it was fine.
Cheers!
Civic Centre
HTC MeteoR
Hi
I use an HTC Mteor with no problems at all in my 2.2EX. Connection was easy and the only problem was after I put my mobile through a washing machine and then a dryer. The HFT saw the phone and then didn't and then saw it again......... Obviously this was down to a daft user and a wet phone and not Honda's HFT. :oops:
excellent
That's good news that it definetly workss with SPV 3100. As for washing things my mum (years ago) acidentally washed a 256mb SD card and reader. She was convinced she'd ruined it, I left it to dry and then it was fine and lost no data - lucky I think!
Chris
Htc S620
Hi
Also works fine on the HTC S620. Got an upgrade this afternoon at work so had to set the new one up tonight. As before, no problems.
