1 - 20 of 25 Posts
Hi
From the comprehensive info on this forum I have been able to establish that my outside tremp sensor is faulty (30 deg C in the Shetland Isles, I don't think so!) Being about as far as you can be from a Honda dealer I need to know how easy the sensor is to replace yourself? Any tips or help would be much appreciated in terms of bumper removal and connecting new sensor.
sensor
mine is also faulty, dealers will replace under waranty
Hi
sensor
Thnaks
Sadly it is past warranty now. Do you know if it is a case of just plugging a new one in. Looks like it is a simple connector once the bumper is off.
From other links it appears you can remove bumper after removing wheel arch trims?
You definitely have the same symptoms that I had. Same ridiculous readings. I'm pretty sure mine affected the heating too, though it was very cold at the time, so I cannot be sure.
Irritatingly, the dealer had the car in, and after a day they rang to say "yes, it is the sensor". A great help! "Just re-book it and we'll order one". For crying out loud; I told them what was wrong! :mad:
Anyway, I hope you can get it fixed. Regret I don't know the cost, as mine was under warranty.
hi im suffering the same problem 55 degrees in glasgow me thinks not lol im not under warranty neither and would rather fix it myself let me know how u get on thanks
When mine was in getting the left wing done they must have knocked it as mine went haywire also. I took it back and it was sorted within 10 minutes and they didn't undo the bumper but i did notice the wheel arch liner wasn't replaced quite right the next day (the LHS one :confused:). Admittedly they had it up on ramps to make it easier
Cockup Specialist
Some grilles are one piece and need the bumper off to remove.
The bumper is reasonable easy to take off if you take your time and be firm without forcing anything or yanking at it.
1. Take the splash guards off underneth.... 2x clips and 2 screws on each side. There is 2 bolts and a couple of clips holding the bumper to the chassis as well while you underneath.
2. Undo the left and right arches... leaver apart the bumper/arch joint with flat blade screwdriver wrapped in cloth to protect the plastic. Then if you pull back the outer edge of the arch you will see 5mm long recesses. There is push clips at these points. You need flatblade/cloth inserted into hear and push on the edge of the yellow push clip until it releases the inner arch. Theres is 3 of these clipse you need to undo per arch. Then at the top of the arch you will see a phillips self tapping screw which fastens wing to bumper on both sides.
3. Start at one end.. pull the bumper toward you and away from the light...firmly but carefully. Now work your way from one end to the other... pulling on several clamping points along the way.
4. Before you completely pull off the bumper...if you have fog lights on, you might like to push the clip on the connector and slide it off the light on both sides.
That will get the bumper off. Replacement is a bit more tricky although in reverse. Make sure the bumper edge slides into the clamping points below the lights and under the grille. DONT FORCE ANYTHING... firm but careful.
Just under the crash beam you can now see... on the left side... is the outside air temp sensor. This sensor just slides on to a metal prong. It has a plug connector nearby for changing the item. If you battery is disconnected... simply unplug, slide off and replace.
I cant stress enough though... use a cloth to protect the paint at all times ;)
Reactions: surferbez
Discussion Starter #12
job done
Hi relic and others. Cheers for info. Very accurate and clear. Bumper off sensor changed bumper back on in about 1 hour. Nice and warm inside my civic now :DStoked!
Cockup Specialist
:thumbsup: :D lovely
Help
Can someone tell me where i can get the outside temp sensor.
I know where it is and i know how to get to it just can't find it on lings
The flying Dutchman
the dealers would be my best guess, i got it there. 38 euros i believe
1 - 20 of 25 Posts
