CTR
Hello,
I'm getting the noted fault code (P2647 - A rocker Arm Actuator System Stuck on Bank 1), very low on power with very little revs
I took the vtec solenoid off (pain to get to) and didn't look like anything was wrong. After re-fitting it I cleared the fault and so far not appeared back
I haven't tried to go into vtec yet but can there be anything else causing the issue before I go get a new one?
CTR
Discussion Starter #2
Update*** hit vtec and light back on with same error
CTR
Yes it was the v-tec solenoid, once replaced no more fault code.
