1 - 17 of 17 Posts
Do the blinds get stuck often of the Pan Roofs? Picked up my Type S GT today and noticed that neither of the blinds will close (they are in the fully open position).
Pressed the button to close them but nothing happens so wondered if there was a common fault with them? I've got warranty with the car so will be contacting the garage in the next few days so sort any issues etc but just wondered if it was a simple fix or not? I can't hear any motor noise when pressing the button so i'm wondering if its just a fuse perhaps?
I have this problem with mine, it seems a little inconsistent, when I open them, the rear opens properly although the front seems to stick, if I tap the blind, it suddenly opens completely, very fast! When I close them, they both close correctly..... Not 100% sure what the problem is :confused:
Would I cause any damage if I manually pulled the blinds to see if they are snagging on something? May be I should just leave it & get the garage to look at it
I had this on my old type s was around £500 to fix by honda I was under warranty from the garage I got the car from so didn't pay
If you still have warranty on the car get it done ASAP to save you having to pay to fix it
I think all they do is replace some brackets but it's a long job which Is why it costs so much
Seems this is common, it has to do with a spring but is a real hassle to fix and involves removing quite a lot of the internals surrounding the roof, mine used to stick when opening but as I always remembered I just gave it a little tap as soon as it started, that way it opened quite normally, if it is stuck and you leave it a second or two and it releases itself it shoots back quite violently. I understand dealers do not like repairing. There is a thread on here where someone manged to fix the spring without removing any headlining - worth a search to see if it could work for you.
more torque than the mrs
mine had to be fixed under warranty 4.5 hours labour, they said the roof lining as to come out and the rail guides had to be changed,not cheap £483 total cost.
roof blinds repair
Hi guys, I've been reading through this thread and noticed that everyone is struggling with these sticking.I'm a honda technician and I do these repairs almost on a daily so I know the costs involved when going to main dealer. Often around the £400 all the way to £700 region! It's also been suggested that it is an all day job when in reality it takes a maximum of 3 hours, I often do then within 2 hours! I thought that I would let you all know that I can replace these privately for £150 including parts if you only have the front blind sticking or £200 if you need front and rear blind shoes being replaced. I would prefer if the car is brought to me but I can come to you if need be. Message me if your interested and in the surrey Sussex are.
Message on here or directly to [email protected]
thats a very kind offer
could you enlighten us as to what causes the blinds to stick and what parts are needed for the repair there's probably quite a few who have the problem but live hundreds of miles away from surrey and maybe would like to have a go at fixing it themselves
any info i'm sure would be gratefully recieved
SKY BLUE ARMY
Mine went in a few years ago under warrant and was an all day job Honda said.
They sorted the issue and was fine until the other day I curiously checked them and front doesn't open at all, had to push it back but it closes fine.
Could I go back to dealer and say the problem is back? its out of warranty now :(
when mine playing up honda replaced the rail guides, took honda over 4½ hours to do the job , for someone thinking of doing it themselves who as never done one double that time.roof lining as to be dropped interior trim removed etc
1 and 3 on the pic Honda Car Parts / Choose by Model / Genuine Honda Parts | Honda Cars | Honda Motorcycles | Honda Power Products | Lings Honda
more info.
http://www.civinfo.com/forum/electronics/94131-failed-sunroof-blind-mechanism-3.html
Why can't you be closer?!! The rear one on mine stuck, then pinged and a part broke off :( is there anyone with contacts in the West Midlands that can do the repairs for a similar price?
Yes unfortunately this is a very common problem. I had mine fixed under warranty and it did take a full day at my local Honda dealer. My car is now out of warranty and I am scared to use my blinds so I just leave them open all the time. When I got mine fixed the Honda technician told me that there was an official bulletin from Honda saying that a single sharp strike with the palm of your hand to the centre of the roof panel (where the blinds retract into) can sometimes release the mechanism, but that didn't work for mine. If I were you I wouldn't try tugging or pushing it back into position as in my case it made the problem worse.
Mine is precisely as the 2nd post.
Sometimes the front sticks, rear never (so far).
It's obvious if it's going to stick so a quick tap frees it no problem.
Always closes without a problem.
Many times there's no problem - so far.
This started perhaps 2 years ago.
Al.
I-Vtec... Do you?
I leave my blinds shut I do prefer them shut but mine used to stick closed then fling open when opening them this was during warranty but Honda I think greased something band couldn't find a fault? They seem ok they stick on a cold morning but not as bad as before great idea but poorly put together
Sent from my iPhone
Thanks, will keep you in mind, I've only had my 08 EX since Saturday and love it. The blind problem was pointed out to me and apparently it had been to honda but fix was temporary. I'm in North surrey so hopefully not to far.
1 - 17 of 17 Posts
