1 - 20 of 21 Posts
Hi guys.
I am currently in the process of installing the Parrot HFT kit in my civic. I use the ISO2CAR cable, but I cant seem to get the mute working. My car is a Sport, which means that I do not have the SAT NAV solution.
Everything else works, it just doesn't display MUTE or anything else on the screen.
How have you mounted the mute function (in the kit there are more than one possibility) ?
Thanx in advance.
Hi!
Right now, I'm removing the dash, but I'm also looking for this information. I need to know what is the color of the mute cable on the original connector on the radio. I'm installing a Nokia CK-W7 kit. According to my information the mute cable should have a yellow color.
As soon as I get there, I'll check it, and let you know. (It'll be in an hour I think...)
Brucez
Hi!
It's funny to know that somebody else is doing the exact same thing as one self at the same time :)
The ISO2CAR cable has a loose pink wire, which I think is the mute wire. I have connected it to the Mute 1 (and 2 and 3) wires from the Parrot cable, but it does not work..
There is no mute display at screen.I have installed the parrot kit but could not remember the mute cable.Now it works perfect.At installation we have tried all the possibilities.
mute
Well, I've just managed to test it, and yes, the yellow wire is the mute. When mute is on, the yellow wire is grounded. And Jackal73 is right, there is no mute or similar message on the display.
So, try to connect your parrot to the ISO2CAR connector that the parrot's mute cable should be connected to the yellow wire in the grey connector. If you'd like to, I can take a photo.
:) Good luck!
And it's realy funny that we're doing the same process in the same time!
Brucez
Me Too
Funnily enough I am about to install a Parrot kit into my car this morning. I also have the iso2car wiring but it is described on the package as a mute adaptor. Will follow your post with interest!
I didn't succeed in getting the mute part working. But its a small problem that I can easily live with.
Otherwise I'm quite glad for my installation.
I finished putting in the ISO2CAR adaptor, it did exactly what it said on the tin! Just slotted together and everything worked including the mute.
Tips for dismantling the dash
Two hints for when you are removing the dash
When prising off the end of the dash use a nylon spatula (wife has not yet noticed that it is missing) and work from the top where the dash is soft and will not mark.
When prising the top off the dash again use the nylon spatula and work from the soft part of the dash, this will avoid making any marks on the hard plastic.
I have the official non-ex bluetooth kit and I still don't get a message on the display.
Connecting the parrot kit using the ISO2Car cable is just a mather of connecting the connectors to each other, forgot all about the loose mute cables, you don't need them (indeed it is a mute adaptor).
'Mute' is also not displayed in my display, but the mute function works very well.
Discussion Starter #12
OK; Yes then the mute function also works for me. What I meant (and expected) was that the CD playing is put on pause when the phone is on. This is what I meant when I say mute function - as the sound itself of course is already muted :eek:
Confused - I am .. [smilie=cheeky-grin:
Confused - I am .. [smilie=cheeky-grin:[/quote]
Ok..
But as far as I know, a mute function only turns off the volume... Never heard of a mute function which pauses the CD playing... But that doesn't mean that it doesn't excist... Only the parrot doesn't....
Discussion Starter #14
To be a bit more precise: When the "mute" input on a car radio is "grounded" the radio mutes its sound and pauses all possible playback. This is normal procedure on most car stereos.
I am not talking about the Parrot. The Parrot system also mutes the sound, but it does it in another way - it just cuts off the speaker signal going from the stereo to the speakers, and inserts its own signal.
That's all true, but didn't know about pausing all posible playback... Never looked into that.... Probably a nice feature for the parrot then...
Steroe removal
Hi all, i am watching this tread with interest, as i am trying to do the same thing, has anybody had trouble removing the stereo, as i seem to be stuck with a clip that i can't see. photos would help if anybody has any
Thanks:oops:
Thanks:oops:
You have to remove the dash like pottsy described in this thread:
http://www.civinfo.com/forum/showthread.php?t=277
After that read this thread for removing the radio:
http://www.civinfo.com/forum/showthread.php?t=301
The radio is attached with three screws on the top side (the screwes are hided by the plate on the dash) and two screwes at the bottom side.
Hope this will help.
Meino Thank for the info it worked a treat,
Now for another question, is the ISO2car adapter part of the parrot package or do i have to purchases it, and will the cabling that is with the parrot box work in th civic?
The ISO2Car adapter is not part of the parrot package, you have to purchase it. The part number is 86131, which is for our Civics and does not only work with the civic and the parrot, it is even required to make the parrot work ;) Or you have to buy a SOT cable (which is the same as the ISO2CAR cable), which some people used here.
1 - 20 of 21 Posts
