· Premium Member
HAY GUYS FINALLY GREW SUM BALLS AND FITTED MY PARROT
the thing is my remote has stopped working changed the battery and still not working is this a common problem or have i just got a duff but of kit can anyone help????
cheers
· Registered
Firstly check the CR2032 battery is properly inserted in the remote unit.
Press and hold the play/pause and green buttons then press the red button several times.
This has to be done when you see the Parrot logo on the display screen.
Within 1 to 2 seconds, you should then see a 'Pairing Remote Control' message displayed on the screen. At that time, you can release the buttons and the remote should then be paired with the kit and the message will go away. You can verify remote operation by navigating through the menus.
If you are unsuccessful on the 1st attempt, power off the unit until you see the 'Goodbye'message, power it back on, and repeat the process.
(this was taken from Parrot's website)
· Premium Member
Discussion Starter · #3 ·
sweet dude will give that a go just seems strange that it suddenly stopped working thats all will give this a go this friday good times : D
· Premium Member
Discussion Starter · #4 ·
DONE must be when the battery dies u have 2 do this everytime kinda suks but works BOOM cheer
