Hey guys. I have found after heavy rain that passengers floor mat is totally wet. I can feel that top left corner of the carpet is wet. Do you have any suggestions ? Thank you for the answer
Not good, have you had the windscreen replaced?
Does the passenger door seal look okay, no nicks/tears/etc? Fully seated?
Is your roof rusty at the top of the windscreen?
Waterspots are right under the a/c vent. Could it be drain pipe ?
Check that the drain into the wing at the bottom corner of the windscreen is not blocked with leaves and other crap.
if blocked the water has nowhere to go but inside the car.
