1 - 9 of 9 Posts
My passenger side window won't work from drivers side or passenger side.
Fuses are fine
Battery reset done
I've attempted the resets but nothing happens as it's not moving at all.
Window lock isn't on either.
What next??
Any help much appreciated
Sent from my C6903 using Tapatalk
Deserter to Lexus
I had a broken wire between drivers and passengers, have the same problem. Mine was broken just where the lookin goes into the drivers door. Very difficult to find, I just re wired it from one switch to the other.
You need to take both for cards off and get a multimeter in there and continuity test the wires, it was a year ago so can't remember where I got the wiring diagram, but the wrote which links both switches had no continuity
Other than that yeah there is a passenger windows lock button
It's not the lock button, tried that already..
Thanks for the input I'll get the wires looked at.
It randomly worked the other day but has since then stopped again.
Bizarre
I found another reset window procedure. The one when you hold down all 3 window buttons and it seems to have worked...
Deserter to Lexus
Lucky, saves a lot of ball ache repairing the wires and finding which 1 is the issue. Good work
1 - 9 of 9 Posts
