1 - 20 of 20 Posts
Cockup Specialist
I love this forum.
Went to put the passenger window down and nothing happened on the way back from CG.
Then realised the auto up/down was dead too.
So I was sitting there thinking great..whats busted and came across the window reset in the wiki last night.
Left the engine running.
opened both doors.
held all 3 buttons down for a good ten second.
held all 3 buttons up for a good 10 seconds.
shut the doors.
...et voila...all good.
Thanks people :D
The D is for Dave
I had exactly the same issue, nice one Relic, I'll head to the wiki :thumbsup:
I love this forum.
opened both doors.
shut the doors.
Thanks people :D
3 buttons? Two on drivers side, and the one on passenger side as well?? All at same time?
Read the Wiki article, mate :cool:
I've had this problem twice (or so I thought)
First time, it was because I had somehow depressed the window lock button :facepalm:
Second time, a genuine problem - the reset procedure worked just fine :D
Hi bud, yeah I have but I am getting differing instructions from forum posts to the wiki thread.
For example the wiki thread does not mention about having 3 buttons pressed? Or I am mistaken?
Just to clarify relic, the passenger window works from the passenger side but not from the ever side....
Cockup Specialist
Yes because my master switch wouldnt lower the passenger side either ;)
Wouldtn have been easier with two people :facepalm4:
I will give this a go with another person lol. What so you mean by master switch EITHER?. Drivers side control won't work., but passenger side does?
Fixed. 10 secs down and ten secs up, but on the passenger side only and it workd. Engine was running when I tried it.:eek:
Bugger need tomtrynthis again. Window reset itself after doing ice upgrade?:p
Confirm again, this works like a treat. Just need to press one button! As described above, engine can be off by the way
ditto just done mine the same way and worked a treat :D just ignition on.. it's great what you learn on here :)
Hi guys I have the same problem on my civic 2.2 i-cdti. It works on the passenger switch but not the master. I have tried the 10 second trick and the reset procedure but hasn't worked also changed the master switch, can you recommend anything else to try.
It stop working after I had the engine remapped.
Dervinator
Weird stuff happened to me with the front passenger window too..
Read the two posts here and try your luck..
http://www.civinfo.com/forum/bugs-faults-irritations/56998-front-passenger-window-not-working.html#post1744960
1 - 20 of 20 Posts
