1 - 2 of 2 Posts
Was hoping somebody could help...
My passenger window works fine when using it from the passenger side however it is no longer is controllable from the drivers side.
Anyone had this problem and / or know how to fix it?
Thanks....
All the other buttons work fine from the drivers side? The window disable etc? It's possible the wiring harness has come partially detatched from the switch? Im sure there is a relay or fuse you could check for power at when you use the drivers switch, to see if it's a switch problem or further down the line, if you have a multimeter?
BFM
1 - 2 of 2 Posts
