Hi all,
Recently was impacted on drivers side by another car, very minor but curtain airbag deployed and was damage to front bumper.
Replaced the curtain airbag, drivers impact sensor and had the crash data deleted. But I'm still left with a 66-17 permanent dtc. From what I've read these codes can't be removed? Do I just keep driving or is there actually a fault still?
319329
id try a second hand sensor or remove it and try clear code then refit
the sensor once activated might not be a reusable item
only experience i had with this sensor was going through a flood but mine reset after drying out yours is saying no signal so its either the case its a once only activation or its faulty or broken wire with impact
Discussion Starter · #3 ·
Thanks for your help. I had replaced the impact sensor which a matching part number.
