Cockup Specialist
A long time ago when I was into tuning cars...
....Pi was not considered the best brand available ;)
For the 1.8.. ABP motorsport have there very own 25/30mm drop Eibachs for the FN2 which will fit the 1.8 (40/45mm drop)
:thumbsup:
The FN2 is already 10-15mm lower than standard.
Replica man
i thought about getting these or even spaxs but after a rethink for the sake of £50 get the Eibach springs which have been testest and liked by 9/10 or maybe even more people.Thats my take on it, i have never used PI springs but from what i know of them there an ok middle of the market brand.
ahh cheers relic :) if I go for the ABP eibach fn2 spring will my shocks get damaged over time due to the drop?
In fact, I can only think of one report in here of someone in here not liking Eibachs - but that was because lowering gave him problems parking at home ...
In a word - NO - but an 'FRS' (front at least) would be a good idea, as you are changing the geometry - at least get a 4 wheel laser alignment check done ...
cheers for the advice! :) once my broken hand is recovered that will be my next project :)
Cockup Specialist
You need to point that question at ABP or a customer ;)
I never tried them myself.
:thumbsup:
I would think long and hard about the pros and cons of 25mm vs 40mm drop.
There is a few threads available on the forum.
I dont believe shock travel is an issue though.
You need to point that question at ABP or a customer ;) I never tried them myself. :thumbsup:I would think long and hard about the pros and cons of 25mm vs 40mm drop. There are a few threads available on the forum. I don't believe shock travel is an issue though.
Certainly, ABP (who did mine) said that the shocks were not an issue with the 25mm standard drop (15mm CTR drop) springs ...
I did have the shocks replaced at the same time (with Koni FSDs) - but they are exactly the same whether the car is dropped or not ...
I'd be hesitant about going to a 40mm drop - 25mm works just fine (better than before) over speedbumps and the like ...
