1 - 10 of 10 Posts
Hi guys, I own a 2007 2.2 i-CTDi Civic with 215.000 km's (=135.000 miles) on the clock.
I reach an average fuel consumption of 7.4 l/100km's (= 38 MPG), while driving city+highway.
A year ago, I had some troubles with my DPF (engine management light came on a few times, oil level rising etc).
- Honda garage replaced the DPF pressure sensor;
- Car still went into a lot of regeneration cycles (and they also lasted way too long) - Honda garage mentioned the CAT couldn't reach the right temperature to regenerate;
- Costs to replace CAT where huge, and if the DPF should have been replaced too, costs were way too high;
- A local (renowned) tuner company removed the DPF + altered the software for the DPF removal and EGR disabling.​
Now I still notice the oil level rising and a higher fuel consumption (about 1l/100km higher-I used to average 45 MPG) than before I the problems with my DPF started (due to a lot of regeneration I can't compare right before<->after DPF removal).
Any thoughts what could be the issue?
Ex-Pat Geordie!
If you had the DPF changed is it not the 2.2 i-DTEC you have?
Reactions: Trev27
Does the oil stink of diesel?
if your oil level is rising its because some other fluid is getting in there
if its water oil will probably go a milky white colour pointing towards head gasket problem
if its fuel then it could still be head gasket or worn piston rings or cylinder bores
I'm betting it's something to do with regen injector cycle still in operation. There's a thread somewhere on here with similar issues. I wonder if you can upload a UK map to the ECU?
Reactions: jeremiah
Discussion Starter · #7 ·
Thanks! I know it's diesel getting into the oil. Before I just thought it was normal due to the regeneration process, just strange it's still rising after the DPF deletion.
Guessing these things (head gasket-piston rings-cilinder bores) are expensive and hard to repair?
Discussion Starter · #8 ·
This is something I was also thinking. Although this particular tuning company already had good experiences with Civic's before...
I don't have upload tools and besides I'm afraid of bricking the ECU by doing things myself...
Especially on a cold engine, the fuel consumption is really high (ca. 7-8 litres/100km = 35-40 MPG).. Because the Honda garage told me the CAT didn't reach the right temperature for a good regeneration, maybe a temperature sensor which is faulty and still causes a regen cycle?
Do you have a link to this thread, because I can't locate it..?
Oldboy-racer
As far as I know diesels don't run both a DPF AND Cat, only one or the other so surprised to here that yours has both.
Good luck sorting it.
Sent from my SM-N910F using Tapatalk
1 - 10 of 10 Posts
