When I go from 1st to 2nd at full throttle there seems to be a slight delay in the power coming back on, Soon as I go into 2nd there is nothing for a second then the power comes on again. Also seems to do it 3rd to 4th. I have an hks rsk fitted and wondering if that could be the cause? Car was last serviced in February.
The fn2 has rev hang from standard, installing a flashpro with custom/groupN map will solve this.
Ah OK thanks. Will be getting a map at some point for the hks and manifold fitting. Does the remap make the gear changes/power a lot smoother then?
Think it's down to the drive by wire throttle, my EP3 didn't do this previously. It's something you soon get used to though.
