hi all
my passenger side power fold mirror has stopped folding, i have swapped the sod over with the drivers side which does work perfectly and still no movement..the glass still moves electrically..does this mean the mirror is knackered or is there a fuse somewhere? or any checks i can do?
someone recently had the same problem and it was a broken wire where the wire comes into the door.
You could try measuring the voltage on it. Pierce the insulation with a couple of pins to make the connection if there isn't a nice convenient place to check it.
right guys i removed the door mirror cover to expose the wiring and upon cutting the black sheath i can now see several wires inside any ideas which are for the power fold motor?
i do have a test meter but to be fair my knowledge of how to use it properly is pretty slim..maybe a trip to the local garage is in order:(
