Hi fellas, just got home from work, went to put my passenger window down to chat to a mate, and it just wont go down now? the window switch doesn't light up on the passenger side or on the drivers side passenger window switch, the drivers window ones fine just not passengers? and also my 12v doesn't work since then, the rear 12v also doesn't work. ive checked the fuses to the power windows and replaced every single one. still nothing, looked in manual because I cant see a 12v fuse anywhere, still cant seem to find the bugger. anyone know where it is or whats happened?
Have you tried the window isolation switch. Its just in front of the window controls on the drivers door panel. It should be in the up position.
im such a donut,malsterl I appreciate the reply! window working just had the isolation switched on, must of lent on it, also changed the lighter fuse aswell as that had blown, fuse 29. big thanks again!
