1 - 12 of 12 Posts
Hi everyone. I bought bc coilovers model BR and i have some problem. i want to adjust hight on rear springs and when i measure same hight on the springs always right side is lower around 1.5 cm then left side between tyre and wheel arch. Any suggestion why is like that?? On the springs and shocks for the back wasnt any label about sides( left or right) just on the front . Could be any diffrent beetween left one and right one shock?? Thanks for answer .
I can't comment on the BC kit but to get my rear arches level I need to set my rear spring perches differently left to right.
I queried this with Grinspeed and they said it was fairly common.
After adjusting the rears you may find that you need to tweak your fronts again. As you adjust one corner, the car kinda tilts around. I think I went around my car 3 times until I closed in on equal arch heights.
It's not dangerous if you set springs differently? Still will be ok for the driving? Even if different will be around 20 mm?
Wysłane z mojego D5803 przy użyciu Tapatalka
Uneven ride heights suggests uneven spring loads, so it's safer to get them consistent.
It's no different from getting corner weights adjusted.
Shouldn't you measure from the centre of the wheel rather than the tyre also to prevent minor miscalculations?
Already i have 10mm different between left and right spring and right side is still lower then left side . So you suggest to set right sprung more higher even if that will be 20mm?? Sorry for that much questions but i want to do that properly. I measure from edge of the alloy i measure from the center of the wheel. I measure lenght of the spring when car was lifted and when car was on the ground.. Same lenght when car was lifted , 5mm different when car was on the ground between the lenght of the springs.
Farqui .. do you have big diffrent between set up left and right springs in your car??
It's noticeable, something like 15mm different as a rough guess.
I can double check when my spacers arrive.
Perhaps the coilovers are sided? Sit in the car and get someone to measure perhaps it evens out?
FYI: my rear spring perches are 11mm different side to side, giving arch heights within a couple mm.
Thanks. I adjust my rear springs with different around 15 mm . Spaces between arches and tyres are the same now :) Thanks for help.
1 - 12 of 12 Posts
