41 - 60 of 153 Posts
We only offer cut vinyl; as it isn't printed we can only use a single colour in one sticker.
I'm sure you could get inventive though, the 'silver over gold reversed' was very creative :)
Im sorry i don't get the 'silver over gold reversed'
any pics or more information ?
thanks.
Got it now
What about the gold part is I was to get that in silver and the rest black ?
How would that look ?
Sent from my Redmi Note 3 using Tapatalk
Discussion Starter #45
The effect in that image comes from using a reversed gold sticker on the inside of the glass, and then a standard silver outside, offset a little. You would get a similar effect - the "outline" wouldn't be complete, more like a silver "shadow". If you aligned the two perfectly, you might see an outline from an angle, but it would be only black looking directly at it.
I hope that makes sense!
Hmm, what about getting a smaller size ?
Has anyone ordered anything smaller than the size stated ?
I'll go for silver gold reversed but in a smaller size please if possible
Or what would happen is I sticked a silver on and then a black one right on top in a smaller size ? Would that work ?
Just wondering
Discussion Starter #48
Just wondering
You could do that, but you would have to re-space out the smaller letters to match up with the large ones - scaling down the image would make the whole thing smaller.
I can make you a custom size, just tell me the length you would like (or height...I can adjust to fit either) :)
Hi
I think the black on top will just be too much hassle
How does a width size of around 150 to 160 mm sound ? can adjust the height accordingly
I will be going for just silver
Thanks in advance
Marc - Posted 18/10
Discussion Starter #54
Silver one for the outside please Marc. The "V" has come unstuck on mine, so a spare "V" would actually do the trick for me.
Please advise.
I'll send you a replacement, easier than making a single letter :)
I caught mine with the scraper last winter...drove me crazy when I looked at the civinfo.co :laugh2:
Please advise.
My first one back in 2007 was a disaster as well.
Since then I've been more careful.
1) Clean with an alcohol pad/meths/white spirit.
2) Apply with centre marks, top - left and right.
3) Remove backing paper very very slowly.
4) Use backing paper to further press all letters and edges.
5) Allow to cure overnight
6) Apply seal wax carefully, centre to outside to avoid snagging edges and enough coverage to cover the area cleaned with alcohol.
Proper Job
I need to wax then
Thanks for the tip, I would have never thought of waxing!
I can't remember which one I used now but a normal solid wax that can be carefully applied to help seal the edges.
Mine's been on since March 13 and not even the pressure washer has affected it, still firmly stuck with no peeling.
