I have a base model with no push button start but in a recent vinyl wrap DIY job i found out how I could replace the blank with the correct switch I found on ebay. The question I have now is how can I wire the push button as a amp switch for my aftermarket amp and sub. Anybody have any ideas?
You would need to replace the switch as the standard is a momentary switch, you need one that when you press in it stays on then you could wire it straight to the blue amp wire on the stereo
Seems to be beyond my knowledge, may use the blanks next to the VSC control instead
