For my new brakes to clear my wheels I need 10mm spacer, am I correct in saying I'll need longer studs?
If you're looking to use 10mm spacers... Then yes, you'll need longer studs... You won't be able to fit 10mm spacers without fitting longer studs. But it is a lot of effort to change the studs :worms:
It's easier to go for 15mm+ hubcentric spacers if you have OEM wheels. There's a reason there's so many people using 15mm spacers... ;)
I'm aware of this but it's to fit brakes and the 15mm kit is too much for me, not that much effort to change the studs just need a little bit of grinding lol
