1 - 14 of 14 Posts
Is the slave cylinder on my civic 2.2d concentric? Garage saying that if its concentric then it's too big a job for them to take on.
Any ideas???
Concentric slave cylinder means internal of the gearbox bell housing
In a nutshell if the slave cylinder is external of the gearbox then its easier to replace and it operates via a clutch fork
A concentric slave cylinder works internal of the bell housing so therefore needs a complete gearbox removal
I just came back to the car and found 2 bolts lying in the footwell, no idea where they came from though
The bolts aren't sheared off or anything, when I put the pedal down there is a pin going through a hole and nothing connecting it, here's hoping I'm gonna get off lightly here
It's not concentric on the 8th gen. It bolts to the outside of the box on the front side towards the radiator
Yeah the bolts look perfect, hoping that they just need put in and tightened, that would be a bonus.
When I bought the car from Arnold Clark they changed it because of the squeaky clutch, might be giving them a call
more torque than the mrs
if it is the master cylinder bolts then i would tell them ,just say the master cylinder bolts have popped out and you guys fitted the cylinder..
1 - 14 of 14 Posts
