1 - 10 of 10 Posts
I put about 4.4 l of oil in my honda fn2. When is stone cold is 3-4 mm over max,when is hot but i am checking about 5 min after i turned off engine is little bellow max and if i am checking about 15 min after i turned off engine is still 3 mm above max.Is that ok? Can i leave like this?
Thank you!
Sounds fine to me mate. The owner's manual says to check with the engine warm and the vehicle level three minutes after turning off. Nothing to worry about or nema problema as they say in your part of the world ;)
Thank you mate!
You serbian is gooood! :D
Where is last sign of oil there is my oil but is very hard to read :S
I pulled out some oil from engine with hose about 250 ml and in on full mark on cold :) Now i just have problem with tunny bubbles but there are miscrocopic and just few of them.Could be ok?
1 - 10 of 10 Posts
