21 - 32 of 32 Posts
Discussion Starter #21
The metal barrels pull out. There could be a circlip. But I swear it judt pulls out. As for the plastic connectors. There should be a thumb push and they come out. They may be a bit stiff at first but they do come off. The speakers are probably just tight and need a little tap. (on the plastic mount). Dude any problems just shout.
graeme, i've a friend who turned his ignition on with the seat out annd had the exact same problem for a while. Another friend pointed him to a local garage who reset the light for a very reasonable £10, it can be done at an independant garage and doesn't have to cost the earth either.
BFM
Blimey, This is brilliant, could you message me all the costings & where you had this done? im geting quotes on stuff like this at the moment
Discussion Starter #26
I would love to but I have done most myself... A lot of the gear is years old so hard to quote money on but the install took probably over 250 hours..
Discussion Starter #27
Well even after 18 months the system is still going strong! Going to be adding and aux inout via clean sweep in the next couple of weeks!
Replica man
my head hurts jst looking at this, going to sound great tho.good luck with the head unit tho wonder what setup your going for there
Discussion Starter #31
Still working
Crazy 4 years on and still loving it. Where can I get a spare top panel that sits above air vent on head unit.. Gonna do a funky iPhone mount...
Discussion Starter #32
Hello all,
Car still going, well after that debacle with replacing the heater blower. I thought as the entire dash is out I would upgrade my phono to jack for phone plug in and add bluetooth connection. I added the JL Audio Mbb-rx. Little box to phono's with male outs. Power and negative for wire up.
All I can say is why have I not done this 2 years ago. The output is so much greater than the line output from your phone and better quality. If your using a phono to jack I would seriously recommend one of these.
Thanks for reading and yes the car is still the same.
21 - 32 of 32 Posts
