1 - 13 of 13 Posts
Could I have a quote for '57 FN2:
Eibach 30mm springs
Eibach 15mm spacers all round
Fitting inc Fast road setup
Thanks in advance
Craig
Eibach 30mm springs
Thanks in advance
Craig
Hi Craig, here are some costs for you;
30mm Eibach sprinrgs £150.00
Eibach camber bolts £25.00
Eibach rear shims £8.50 (each)
Eibach 15mm spacers £110.00 (per axle)
labour to fit all the above and set geometry £275.00
Total for everything £704.00 inc VAT (worse case) That is if we need to use all 4 shims, but the likelyhood is the total will be less than that.
I hope this makes sense, please let me know if you have any other questions or if you want to get the parts sorted or booked in.
Rich
Hi Rich,
Thanks for the reply.
In your experience is there much benefit from having the spacers and if so is it best to have everything done at the same time?
* are the spacers the bolt on type that can be installed/removed easily?
Thanks Craig
I'd say the spacers are more of an aesthetic modification. When the Civic is lowered, it becomes more obvious the wheels are set in quite alot in the arch. The spacers bring them out perfectly and give a great, wider look too.
They are the easier, system 4 spacers too. They fit just like a wheel does and work perfect with standard, Honda wheels. We don't charge any extra labour when fitting them after doing springs.
Rich
Hi Rich,
I did think that and to be honest I would probably want them and at the same time but wow they're expensive aren't they!
Thank you for the info I'll need to have a think and factor in the travelling time/distance.
Cheers Caig
No problem at all.
The spacers come with all the hardwear which is why they're quite expensive.
Let me know if you'd like to book in or if you have any other questions.
Rich
Discussion Starter #12
Hi Dave,
Springs being fitted next Tuesday, been a bit of a nightmare finding someone to fit, shame you guys are so far away. Are you emailing the settings or do I need the alignment done first and readings sent to you?
Cheers Craig
Hi Dave,
Cheers Craig
Just PMed you Craig with the details.
I do need a printout to work out which shims (if any) for the rear.
Hope this helps?
Dave. :D
1 - 13 of 13 Posts
