Hi.does anyone knows the actual weight of the oem radiatior of the fn2?i checked out that the aftermarkets are about 6.5-7kg....i want to know if there is any weight difference between them.I know that the aftermarket are made from light alu...but they are a little bigger in the size.i just want to know the weight of the oem radiator in the fn2...thanks
I've never seen the radiator come up in weight saving threads, so I wouldn't have thought it was an area where you could lose some serious kgs. Get rid of your aircon for a proper saving - if you can stick the summer heat in Greece!
If i save 1-2kg...and achieve better cooling...so that i can push it for 30min and the performance is stable....without loss of power...i am ok buying it.
You potentially wont save weight due to extra coolant required in bigger capacity rad but better cooling effiency is still worth it.
